SURPRISE ! - Ubuntu 12.04 is actually pretty good !
- SURPRISE ! - Ubuntu 12.04 is actually pretty good ...
Re: SURPRISE ! - Ubuntu 12.04 is actually pretty good !
06-05-2012 8:05 PM
$ sudo lshw -C network
Quote *-network:0 UNCLAIMED
description: Ethernet controller
product: IPN 2220 802.11g
vendor: InProComm Inc.
physical id: 2
bus info: pci@0000:02:02.0
version: 00
width: 32 bits
clock: 33MHz
capabilities: pm bus_master cap_list
configuration: latency=64 maxlatency=32 mingnt=32
resources: ioport:a480(size=32) memory:e8201000-e820101f memory:e8200800-e8200fff
*-network:1
description: Ethernet interface
product: RTL-8139/8139C/8139C+
vendor: Realtek Semiconductor Co., Ltd.
physical id: 3
bus info: pci@0000:02:03.0
logical name: eth0
version: 10
serial: 00:02:3f:09:fb:09
capacity: 100Mbit/s
width: 32 bits
clock: 33MHz
capabilities: pm bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=8139too driverversion=0.9.28 duplex=full ip=192.168.1.73 latency=128 link=yes maxlatency=64 mingnt=32 multicast=yes port=MII speed=100Mbit/s
resources: irq:19 ioport:a000(size=256) memory:e8201400-e82014ff
sudo lspci -v
Quote 02:02.0 Ethernet controller: InProComm Inc. IPN 2220 802.11g
Subsystem: AMBIT Microsystem Corp. T60N871 802.11g Mini PCI Wireless Adapter
Flags: bus master, medium devsel, latency 64, IRQ 11
I/O ports at a480
Memory at e8201000 (32-bit, non-prefetchable)
Memory at e8200800 (32-bit, non-prefetchable)
Capabilities: [40] Power Management version 2
I don't get anything from dmesg | grep wlan0
06-05-2012 9:18 PM
There's a bug report about the ndiswrapper package being broken on 12.04.
06-05-2012 9:19 PM
sudo modprobe ndiswrapper
Quote FATAL: Module ndiswrapper not found.
ndiswrapper is installed I can access adding windows drivers from a gui, perhaps ndiswrapper needs updated or something, I have seen posts to that effect but not actually how to do it. Also disabling the built in drivers might be something to do with it.
06-05-2012 10:09 PM
Installing the driver using ndiswrapper gui i get an error message.
Module could not be loaded. Error was:
Is the ndiswrapper module installed?
Although it does say after that that hardware is installed!
ndiswrapper -l gives the results neti2220 : driver installed device (17FE:2220) present
sudo depmod -a
sudo depmod -a
sudo modprobe ndiswrapper to associate the driver
06-05-2012 10:45 PM
06-05-2012 11:02 PM
07-05-2012 2:54 PM
07-05-2012 3:31 PM
You install the Xubuntu meta package and this allows you to use the Xubuntu or Unity<spit> interfaces.
(Choose at logon time)
Xubuntu is a much lighter weight interface - and you get Menu's etc
07-05-2012 3:56 PM
07-05-2012 3:58 PM
07-05-2012 4:05 PM
07-05-2012 4:13 PM
What is the make and model of your laptop ? - and I will see what I can come up with.
07-05-2012 4:18 PM
07-05-2012 4:26 PM
I suggest one stick is enough - unless you are doing video processing etc.
07-05-2012 4:44 PM
Regarding 'A Fox is Evil's comment, my laptop is still running Ubuntu 10.10 and has been using 2x512MB memory for the last year, and in general 1GB was perfectly adequate.
However recently I have been using the machine heavily with perhaps 6 or 8 programs running simultaneously, and with more than a dozen webpage tabs open at the same time, and it was just going over the top and using the swap file - so I simply upgraded to 2GB. I think for most people 1GB in Ubuntu should be enough, but if you are upgrading from a single 512MB, then fitting 2GB seems reasonable while you have the machine apart.
