SSH over WAN
bobpullen
Fixes: 194
Re: SSH over WAN
Quote from: kmilburn
I have SSH forwarded from a non-standard port on the router to the default port on the sever  (also a raspberry pi),  and (so far) don't get any unwanted traffic.
As a secondary security measure,  tools like Fail2Ban or DenyHosts can monitor the logs and block IPs with too many failures.
This is what I've done. Forwarded a non-default port on the WAN interface to the default port on the LAN interface, poked a hole through the iptables and installed fail2ban.
Re: SSH over WAN
Quote from: chenks76
Quote from: dvorak
same was as you do it on any platform... but here's a link https://www.raspberrypi.org/documentation/remote-access/ssh/passwordless.md
that's all very well, but the device i am connecting from is a windows 7 system, and that document only refers to connecting from linux/unix systems.
You can get OpenSSL for Windows and it comes with all the tools you need. Certificates, keys etc created on one OS can easily be used on another.
ejs
Fixes: 25
Re: SSH over WAN
OpenSSH doesn't actually use SSL, nor certificates. It uses ssh keys. You could create the keys on the pi, then copy the private key to the Windows system.
chenks76
Fixes: 12
Re: SSH over WAN
not sure if that can be done on a sky router (SR102)...or can it?
kmilburn
Re: SSH over WAN
On the windows client front,  I use Putty for shell access,  and WinSCP for transferring files over ssh.
VileReynard
Fixes: 20
Re: SSH over WAN
I wouldn't use ssh over the external internet - you will get dozens of attacks on port 22 each day.
The default user name is usually 'pi' on a pi device - not actually really secure.
It's worth setting up ssh though, as this also gives you a ftp connection (using sftp with the ssh user & passphrase).
Additionally, I use a VNC server on the Pi so that I can control a GUI interface via a PC VNC client.
chenks76
Fixes: 12
Re: SSH over WAN
Quote from: vilefoxdemonofdoom
providing they don't guess the non-dictionary password then it doesn't matter how many attacks.
changing to a different port won't stop the possibility of attacks.
VileReynard
Fixes: 20
Re: SSH over WAN
Given a choice of attacking a single port or many thousands, your average spammer just aims at 22.
There is nothing stopping you running a honeypot on port 22 and the real ssh port on some other number.  Cheesy
ashgeo
Re: SSH over WAN
Thanks everyone.... Cheesy Interesting! I've installed Fail2Ban and eventually got it configured. I've forwarded a random port on from WAN to the ssh port on the Pi (via my two routers!) and have successfully tried to hack into it, and have been banned! It will be interesting to keep an eye on the logs over time.....
ashgeo
Re: SSH over WAN
I've had it up and running now for almost a month and no-one has yet tried to hack into it.... Logs on rPi are clean! Thanks everyone. Touchwood it continues....
SteveA
Re: SSH over WAN
you can also set up hosts.allow and hosts.deny to control access.
Also denyhosts is worth looking at.
VileReynard
Fixes: 20
Re: SSH over WAN
Not using port 22 is what gives you the most protection (by obscurity) - although obviously a half-serious attack would easily find your chosen port.
kabads
Re: SSH over WAN
You can install something like fail2ban or denyhosts which will pick up on failed logins and add them automatically to /etc/deny.
