SSDs getting bigger
w23
Fixes: 4
SSDs getting bigger
No pricing yet but probably a little on the expensive side...
http://www.dabs.com/blog/index.php/worlds-largest-hard-drive-samsung-16tb-ssd/?utm_source=facebook&u...; Shocked
Call me 'w23'
19 REPLIES 19
twocvbloke
Re: SSDs getting bigger
With 16TB, who needs media compression? Just store everything in a raw, full-resolution, unmolested bitrate state... Grin
thejudge
This reminds me of those little doobries you used to be able to get which held eight £1 coins....which meant that when you lost it, you lost £8 rather than just £1.
The trouble with things like this is that the more data you store on them, the more you'll lose when they die on you. I've just had to replace a 1TB external drive, and reloading everything onto that is being a right pain.
VileReynard
Fixes: 20
SSD's are also getting smaller.  Cheesy
You can get 30GB ones for about £25.
Anotherone
Champion
Fixes: 21
32GB USB sticks are cheaper I thought?
VileReynard
Fixes: 20
USB sticks are always cheaper.
twocvbloke
They're also slower compared to SATA... Grin
nanotm
well according to a blog I read last week ssd's are actually slower than 7200 hdd's for retrieval due to them being a mish mash of multiple storage controllers all getting in each others way as data retrevial operations are triggered, apparently anything over 250gb has this problem due to the multi chip storage system being used
so whilst 16tb ssd might be great in theory unless they find a new way to do the memory control interface it would be faster to retrieve info from a set of encyclopaedias in the local library than to get the info out of the last storage chip in that drive after a few months of daily use ....
Anotherone
Champion
Fixes: 21
Quote from: nanotm
............... unless they find a new way to do the memory control interface it would be faster to retrieve info from a set of encyclopaedias in the local library than to get the info out of the last storage chip in that drive after a few months of daily use ....
Grin Grin Oh I do like your sense of humour on occasion, but you forgot to include the bus journey time to the interface library.
w23
Fixes: 4
Then there's the wait time for the bus, I believe SSDs usually support 'Native Queueing'  Grin
Call me 'w23'
nanotm
ah but native queuing and bus transit times between interfaces are common to both options so are negligible in that regard.....
and in case anyone wasn't clear far from being a serious comparison its an alliterative illustration of the excessive wait time introduced by the multiple "wait while I check" commands being issued within the ssd, as each individual cluster (chip) controller works in series rather than parallel, and each one has 64gb of storage giving you up to a 30 second wait time for a few small files that are being accessed across multiple storage segments within each of the chips (a by product of wear levelling doing its job to well) on a busy device.....a serious problem that has started to cause problems for a lot of server farms that had opted for larger drives under the illusion that they would be faster thus allow greater throughput across multiple endpoints than the cheaper and actually faster over time hdd's...
twocvbloke
Quote from: nanotm
According to my experience of a Mushkin Chronos 120GB SSD with a 1TB Western Digital Blue 3.5" 7200RPM HDD as the system storage, the SSD wipes the floor with the HDD... Grin
chenks76
All Star
Fixes: 12
Quote from: nanotm
what blog was that?
one written by an idiot? or just a blog read by one  Grin
VileReynard
Fixes: 20
Do SSD's give any warning of impending failure?
Traditional hard disks often do.
twocvbloke
Quote from: vilefoxdemonofdoom
I'll let you know after I get past the 90,000 IOPS quoted for my Mushkin... Grin
