SSD
SSD
02-01-2014 11:54 AM
Anyone use it and if so have you found it reliable ? or come across any snags ?
Re: SSD
02-01-2014 12:00 PM
Oh, and a replaced one from my desktop in a USB drive too.
Can't say that I've ever had a problem at all!!!
York.
Re: SSD
02-01-2014 12:08 PM
Re: SSD
02-01-2014 12:17 PM
Startup is fast but I like the fact that entering/waking from Sleep mode is lightening fast.
Forum Moderator and Customer
Re: SSD
02-01-2014 12:34 PM
I use a normal 1 TB WD Caviar Black for the data storage.
Computer boots up / shuts down fast, never had any issues with the SSD.
Re: SSD
02-01-2014 12:49 PM
Enable TRIM within Windows (I think 7 and above) and disable automatic Defraggmenting for the SSD as it won't make any difference but may help reduce the lifespan of the drive if enabled.
More advice here.
Edit: This site was recommended in this forum when I was asking about SSds almost two years ago.
Re: SSD
02-01-2014 2:50 PM
Re: SSD
02-01-2014 4:19 PM
Thanks very much.
Re: SSD
02-01-2014 5:36 PM
Another handy SSD link http://www.thessdreview.com/ssd-guides/optimization-guides/the-ssd-optimization-guide-2/
Re: SSD
02-01-2014 6:26 PM
As above (Never Defragment a SSD) as it not only degrades the lifespan, however it can also VOID the Warranty with some manufacturers if the SSD has been defragmented)
SSD(s) were originally made to go into business servers as they are more robust the IDE / Sata drives
Re: SSD
03-01-2014 1:29 PM
Don't think that's only for raid (though I'm using it as such).
Re: SSD
03-01-2014 6:57 PM
Re: SSD
03-01-2014 7:04 PM
Why do i need AHCI with a SSD Drive
Re: SSD
17-01-2014 3:05 PM
Quote from: vilefoxdemonofdoom Have a substantial number of SSD's survived more than a couple of years without failing?
Have a look at the attached pic of my old Crucial C300 64GB SSD.
It's over 3 years old now ( used as an OS drive ) and still going strong.
According to SSDLife it's got longer left than my month old Samsung 840 pro
Re: SSD
17-01-2014 5:13 PM
