SSD's & HDD
- Re: SSD's & HDD
SSD's & HDD
19-05-2014 2:15 PM
As the cost of SSD's is much greater than HDD's it's likely that the latter will be around for some time but as the price of SSD's falls is it likely HDD's will be phased out in a similar way that floppy disks were phased out or will there always be a place for HDD's ?
We are born into history and history is born into us.
6 REPLIES 6
Re: SSD's & HDD
19-05-2014 3:08 PM
WInd the clock back a decade. When flash cards first came out, they were small, expensive and, we were storing data on floppy discs - in a range of funky colours. And we used lots to do backups and port data from A to B. Admit it, who now uses floppy discs? That said, some people still do. And there's tech diehards still using zip drives and mag cartridges. It is enevitable that someone will invent a way of fabricating SSDs dense and cheap ( using graphine maybe ). The poor HDD, even those 1Tb devices, is heading for back of the cupboard where all the other dead formats reside. As for HDDs in this transition period, they'll still be at the core of systems that are data hungry, such as photos, movies and music - but in the cloud.
On the desktop, the rattle and clack of the HDD inside the case will soon be a distant memory, like the clunk whizz of the VHS recorder.
Re: SSD's & HDD
19-05-2014 3:10 PM
Also not to forget the PCIe connected SSD are become more available with larger sizes, OCZ have a 320gig revo drive now
Re: SSD's & HDD
20-05-2014 4:38 PM
Quote from: rongtw Also not to forget the PCIe connected SSD are become more available with larger sizes, OCZ have a 320gig revo drive now
I think their 480GB is due out soon as well, over 1200MB/s on both read and write which is insane!
I've recently upgraded from a mechanical to solid state with read and writes of 500+MB/s and the contrast is pretty noticeable, I can only imagine that the Revo opens programs before your mouse pointer reaches the icon!
Re: SSD's & HDD
04-06-2014 12:03 PM
I would imagine there will be a place for HDDs in server centres for some time to come: SSD has the issue that data can only be overwritten a relatively limited number times. While that's fine for most uses, it's not so great where you have highly volatile data.
There's still plenty of tape being used for backup after all - and that ancient (1960s?) tech is still being developed.
Re: SSD's & HDD
04-06-2014 2:43 PM
i've got a 500GB SSD in my main laptop and there's a 240GB SSD in the secondary one, other machines are still running HDD.
I did have one fail but it was replaced under warranty and as it was regularly backed up didn't cause too much hassle.
Re: SSD's & HDD
04-06-2014 3:07 PM
Quote from: Thunderclap On the desktop, the rattle and clack of the HDD inside the case will soon be a distant memory
If only all the numerous fans would go as well.
