SSD's (Again)
- SSD's (Again)
SSD's (Again)
03-01-2014 7:07 PM
I am asking this should I have any reason to think my existing hard drive was on the way out.
Re: SSD's (Again)
03-01-2014 7:20 PM
It can sometimes be a time consuming job
Although there a programs that make the job easier to bear
As for fitting into the same connectors or spare connectors inside your case,
It is hard to say as we do not know what make model your pc is and what connections you have
sometimes its as simple as plug and play and sometimes you may have to change settings in the BIOS (Basic Input Output System)
Re: SSD's (Again)
03-01-2014 7:21 PM
However if you are using an OS that is more than a couple of years old, you might want to read up on how to format the SSD so that the partitions fall on a particular optimum page boundary, so that SSD writes are minimized by having the drive format correctly aligned, rather than having sectors spread across flash memory page boundaries.
You should Google the model of SSD and the version of OS, to find the preferred settings.
Re: SSD's (Again)
03-01-2014 9:10 PM
This is due to the difference in page boundaries as mentioned above as well as differences in how the data is accessed.
I went for the clean install.
Forum Moderator and Customer
Re: SSD's (Again)
03-01-2014 11:46 PM
If your system comes with an OEM OS (EG I have Win7 pre-installed) what happens then?
I have an image on a hidden partition but I can burn that to CDs (can't be bothered lol!).
How is that handled?
Re: SSD's (Again)
04-01-2014 7:38 AM
older PC,s will normally have a EIDE cable to connect the HD this will not ! fit to a SSD , also the power lead is different.
dick:green Duplicate post removed.
Re: SSD's (Again)
04-01-2014 8:37 AM
These EIDE SSDs normally have the 44-pin laptop connector which has both the data and power pins in one connector.
If you needed to fit one of these to a PC that had separate 40-pin IDC ribbon + molex power, then you would require an adaptor such as these -
Having looked at the specs for EIDE SSDs, the read and write speeds are generally poor compared to the fastest EIDE hard drives, so the only gain you will see is the near zero latency of the SSD compared to mechanical hard drives.
Alternatively, you could buy an SATA interface card to fit in a spare PCI slot, so that a faster and cheaper SATA SSD could be used.
Re: SSD's (Again)
04-01-2014 2:10 PM
Based on what's been said on this topic I would be going for SSD should any problems occur with my HDD's
Fortunately I have got Windows 7 on Disk so would go for a clean install then add Linux for a dual booting system.
Re: SSD's (Again)
04-01-2014 2:22 PM
You can't easily do that with Windows.
Re: SSD's (Again)
04-01-2014 2:40 PM
I have 16GB RAM and the paging file is set to 16GB on a separate internal HDD which, as far as I am aware is rarely, if ever, used.
Re: SSD's (Again)
04-01-2014 6:24 PM
Assuming that you aren't changing a load of other hardware (e.g. CPU, graphics card or network card) at the same time, it shouldn't complain about activation.
There is one possible complication. You're really better off running the SATA controller in AHCI mode, and that way things like TRIM will work properly. If it's in legacy IDE or some nasty proprietary software RAID mode (e.g. NVRAID), you won't get TRIM. Without TRIM, you will get performance degradation of the SSD over time. If Windows has been installed with the SATA controller set to IDE mode and you change it to AHCI (in the BIOS), it might fail to boot (although I have done it before, but can't remember the exact steps that I took).
Re: SSD's (Again)
04-01-2014 7:10 PM
Re: SSD's (Again)
07-01-2014 9:37 PM
i have an asus p5g41t-m lx and have been trying to activate achi for two weeks until i found out today that there's no support on this mobo.
despite this win7 runs a hell of a lot faster on sata ssd than on ide hdd and yes i know i won't get trim support but i'll just have to live with it.
i've learned a lesson for next time but i'm not sorry i went for it.
jack
Re: SSD's (Again)
07-01-2014 10:16 PM
Alternatively use Linux and just type one word into a configuration file.
Although you won't get command queuing, it won't make any great speed difference.
It will reduce the lifetime of the SSD.
Re: SSD's (Again)
08-01-2014 8:39 AM
Quote from: vilefoxdemonofdoom You could look at http://forums.pcper.com/showthread.php?444831-HOWTO-enable-AHCI-mode-after-installing-Windows
thanks for that link but i have downloaded and installed winfixit for the subject matter and changing the bios from "enhanced to compatability" rendered all sata boot devices undetectable. naturally i have reversed the bios setting.
reference to achi in the boot menu is null---------i just cannot find it-------mobo doesn't support it.
which part of the mobo doesn't support it i wonder------could i replace the cpu to achieve my goal--i'll have to research it via google.
jack
