SSD's (Again)
- Re: SSD's (Again)
- « Previous
- 1
- 2
- Next »
Re: SSD's (Again)
08-01-2014 8:51 AM
The Intel G41 chipset on the motherboard doesn't support AHCI.
You could gain AHCI support by adding something like an ASM1061 PCI Express card, if you have a free slot. I probably wouldn't bother though.
Re: SSD's (Again)
08-01-2014 8:07 PM
Quote from: CX The Intel G41 chipset on the motherboard doesn't support AHCI.
that's something to consider in the future cx. i only have sata 3gbs so i should see an increase in speed to 6gbs.
my one remaining slot is pcie 16 though for graphics cards but i've just watched a guy on youtube fit the pcie 1 into a pcie 16 cause it is faster and it works.
lots to think about.
jack
- « Previous
- 1
- 2
- Next »
