SSD for my rebuild - discussion
- SSD for my rebuild - discussion
14-04-2015 12:39 PM
Now this is all well and good but looking at my present usage
The system drive plus My Documents is about 130GB so a 250GB would be large enough for the foreseeable future but would be useless for storing games.where 30GB plus now seems to be the norm.
So my real question is whether there is any merit in getting a 500GB SSD drive or indeed 2 x 250GB SSD or whether a single 250GB with my present 1TB hard drive would be the way to go as I understand that the only advantage of an SSD in games is loading times with no effect on frame rates
There is another option - keep the bulk of the games on the HDD but move/reload the current used games to the SSD
Thoughts please
Of course the other factor is whether PCIe M2 drives will ever become cost effective and whether the speed increase would be really noticeable
Re: SSD for my rebuild - discussion
14-04-2015 12:43 PM
big mechanical HDD for storage
14-04-2015 1:36 PM
I've already bought a 500Gb Samsung EVO SSD & another Pioneer BD-XL drive as upgrades, don't need any memory got 16Gb of that. Just need to update the GFX card as well!
14-04-2015 1:43 PM
14-04-2015 2:18 PM
If the game is intelligent enough to do look ahead to preload into memory the code and data it might need and the issue is simply fast startup, then the best option is probably as big an SSD as you need to install the OS and the games.
If the game is less smart, and needs to go to disk very frequently while playing (which may slow the response if not the frame rate), then you probably have two or three options. The first is a big SSD as before. The second is one of those hybrid hard drives. The third ( assuming you have a suitable chipset/motherboard) is an SSD for the OS and a smaller one (64GB max?) to act as a cache for the mechanical drive using Intel's smart response technology http://www.intel.co.uk/content/www/uk/en/architecture-and-technology/smart-response-technology.html
14-04-2015 2:34 PM
Quote from: Oldjim so what would you have on the SSD where the improved access/loading would be of a real benefit
The minimum possible, just the OS & Swap file, things like Office. If it's valuable, then keep your "working" copies of stuff on another disc or on a USB stick/SD card.
14-04-2015 2:55 PM
all program's are installed on my 1TB , as they dont need as much speed to start , main advantage for me is faster loading for games
14-04-2015 3:03 PM
However loading times - specially while playing - would be a real benefit
One thing I did find out was that with Steam Games you can move them between drives fairly easily as you can now setup steam to use two different drives for games storage
I wouldn't go for a hybrid drive as they are rather old technology with the price of SSD's dropping all the time
14-04-2015 3:30 PM
I found some stuff getting its knickers in a twist and most programs stored data and configuration on the SSD anyway no matter what I did.
On a second installation I let everything install on its default (SSD) and relocated the Libraries to another drive.
Currently the SSD has 393GB free and 73GB used out of an available 466GB
14-04-2015 3:40 PM
Could you not clone your SSD to the hard drive so that you have some kind of backup?
14-04-2015 3:45 PM
I don't backup my games drive as it is firstly too big and secondly it can all be reinstalled if necessary
14-04-2015 3:47 PM
The SSD has an hourly incremental backup.
14-04-2015 8:18 PM
I have got another 100GB SSD installed and that is used for temp files especially when rendering which gives some great speed improvements.
I am in two mind as to whether it would be better to switch the usage between the two SSDs by making an image of the 60GB and copying that to the 100GB and making that the boot or simply uninstalling the apps that don't really have any benefit of loading any faster from SSD and re-installing them on HDD. I suppose I could install them on the 100GB SSD instead.
It's something I need to address soon.
Forum Moderator and Customer
14-04-2015 8:49 PM
Heck, when starting up, the windows logo is barely onscreen before asking for my password...
14-04-2015 9:02 PM
personally I have the my docs file origin and steam all on separate tb drives (all wd black 1 or 2 tb units) with the os and most program files on the ssd (Samsung evo 840 pro 256gb)
if I was buying to build a new pc i'd probably do this and limit the ram to 8gb as ram costs more than the ssd's do most of the time.....
