SONOS Speaker Issue
robdtweddle
SONOS Speaker Issue
I’ve just joined Plusnet & gone through the set-up procedure to re-connect my Play 1. However it will not play when wireless. It works fine when connected via the Ethernet cable but when I then disconnect the Ethernet cable it doesn’t play. When I tried the set-up procedure via the SONOS app on my iPhone X I get to the point where my phone is connected to the SONOS via Wi-Fi however when I go back to the App it says I’m not connected to the SONOS Wi-Fi Network. Any help would be much appreciated.
Tags (2)
2 REPLIES 2
leechinnery
Re: SONOS Speaker Issue
Hi did you get a resoluutiotn to this issue?  Having the same problem as my Sonos does can not find the Plusnet router.
Thank you.
Fixes: 419
@leechinnery
See your other post https://community.plus.net/t5/Fibre-Broadband/Sonos-Surround-does-not-pick-up-Plusnet-Wifi/m-p/17001...
Posting the same query on different boards causes confusion.
