SMTP Error failure
ukanimal
SMTP Error failure
using thunderbird keeps asking to add my password - which I keeping doing and it keeps saying failure
using webmail.plus.net  it also says smtp error failure
Is this something my end or with plus.net ?Huh
If just seems to be on one account not the others
3 REPLIES 3
ukanimal
Re: SMTP Error failure
I'm receiving emails no problems at all, I just cannot send them - so it's not a password problem
VileReynard
Fixes: 20
Thunderbird assumes that a connection failure to the SMTP server must be because you used a bad password.
It doesn't distinguish between a long standing problem with Plusnet email and an authentication failure.
ukanimal
thanks Smiley
it's hit and miss now so it could be something simple - but thanks for your reply
