SCO is dead
- SCO is dead
SCO is dead
10-08-2012 9:32 PM
http://www.zdnet.com/sco-is-finally-dead-parrot-dead-7000002357/
3 REPLIES 3
Re: SCO is dead
10-08-2012 10:24 PM
so they've finally switched off the life support. what a relief.
Re: SCO is dead
11-08-2012 1:06 AM
Not quite, but effectively they are going through the motions to get it turned off...
As usual, the only winners of this 9 year saga are the lawyers , apart from what the McBride's and other senior management manage to extract (or extort) in the process!
Re: SCO is dead
13-08-2012 12:30 PM
Quote Maybe you should read the GPL, especially the part where it says you are forced to give up your code. That's not being free.
Americans do my head in...
(edit - quote from comments on link, btw...)
