SATA cables
FIXEDTopic Options
- SATA cables
18-02-2018 5:03 PM
Dumb question, first build using Sata...
Does it matter what end is connected to what?
Fixed! Go to the fix.
4 REPLIES 4
18-02-2018 5:15 PM
Nope they are universal
Re: SATA cables
18-02-2018 5:20 PM
Re: SATA cables
18-02-2018 6:21 PM
If you aren't using a new power supply does it have enough SATA power cables otherwise you will need some adapters - they are cheap enough off Ebay
Re: SATA cables
18-02-2018 8:06 PM
No idea Jim I've yet to look inside both current machines to see which psu is easiest to remove and use for this build lol.
