Run multiple desktops at the same time
Fixes: 15
OMGUbuntu have Mate running on top of Gnome shell
http://www.omgubuntu.co.uk/2013/02/how-to-run-mate-desktop-in-gnome-shell
Seems like a waste of Mate to me  Cheesy
(HB running Linux Mint 14 64bit Mate edition)
Fixes: 16
Re: Run multiple desktops at the same time
By "MATE Desktop", they mean the MATE panel.
Having a whole other shell can be useful too. Say GNOME Shell were to crash, MATE would still be there giving you easy access to your entire system and apps.
If GNOME shell were to crash, either it gets restarted, or you get the "Oh no something has gone wrong" screen shoved in your face.
Unity sucks too and has adware/spyware.
Interested in that comment from the link  Huh
Fixes: 15
It refers to the Amazon tie in I believe. Your searches (even desktop ones) get punted out to Amazon. Not something I want/need.
Me neither, Tax Dodgers  Grin I'll look into stopping that when I get home.
VileReynard
Seasoned Pro
Fixes: 9
Why did they name it Unity?  Crazy
I thought it was because it was uniting desktop, tv, mobile and pad with the same looking interface.  As for precise pangolin I think that came from use of magic mushrooms  Grin
Fixes: 15
I still say it was a miss-spelling it should have been UnUtty!
Still as I haven't use U for 5+ years now I am not worried. Mint is moving away from a U base as well, slowly but surely. As the underlying changes are made it makes it harder to use it as a base.
Take the next move to a new X, how many apps will that kill? Or will there be a compatibility layer for X11 based apps?
I must say I've been rather disappointed with the 12.04/12.10/Unity etc. Ubuntu is becoming bloated and being presented with Amazon rubbish when I type in the search bar is shocking.
I've now got into the habit of installing the server edition then installing XFCE4 or similar
sudo apt-get remove unity-lens-shopping
The shopping lens can be removed from unity. I'm proper confused with desktops at the minute, I had a look at gnome from the software centre to try and get back a bit more old skool which was ok on one computer but the other looked even more complicated than unity to navigate. When I had a look at mint there was lots of difference of opinion on which direction that was heading as well. I wish I knew the future, I just like to stick to one and modify to my liking.
Fixes: 15
Well for old school you have:-
Xfce
LXde
Mate
New "phone" os's
Unity
Gnome shell
Alternate new school:
Kde
Cinnamon
On the edge
E17
If you want a modern looking one try Cinnamon, you can install it from a deb/ppa. I prefer Mate and it is getting better with each release. Used My Mint & Fedora along with a few other less well known distros.
VileReynard
Seasoned Pro
Fixes: 9
Seems that Canonical is putting its major efforts into things that no one wants (rewrite of X, Unity desktop etc).
Fixes: 13
Quote from: vilefoxdemonofdoom
Sounds like they have the M$ bug then  Cheesy
So out of all these desktop environments does any of the use less resources than the other? I suppose if you have to have something else running to change the desktop then sticking to the original one out of the box should theoretically use the least no?
Fixes: 15
Nope a desktop environment can be quite a resource hog.
Something like LXDE uses less raw power/memory than something like Unity/Gnome 3 shell.
Installing several desktop's will use disk space but dependant on which is running will effect your free resources (ram etc). Also the background you have can make your desktop slower as well. Really depends on how high spec your graphics card/driver and ram are.
On my P4 laptop it is better on LXDE than Gnome 2/Mate.
