Routers firewall
Fenster
Routers firewall
Hi, maybe someone technically minded can help me, I have just got a D-Link 2640b wireless modem router and zonealarm firewall, would there be any advantages or disadvantages to turning on the routers firewall as well ? thanks.
Re: Routers firewall
why not?  you can run as many firewalls as you like.  your router itself, with network address translation, also acts as a firewall.  with windows, if that's what you're using, you need all the protection you can get.
Fenster
Thanks for that , just didn't want to do anything that may cause any problems when everything is working ok.  Smiley
