Routers firewall
- Re: Routers firewall
Routers firewall
17-05-2008 12:28 PM
Hi, maybe someone technically minded can help me, I have just got a D-Link 2640b wireless modem router and zonealarm firewall, would there be any advantages or disadvantages to turning on the routers firewall as well ? thanks.
2 REPLIES 2
17-05-2008 2:45 PM
why not? you can run as many firewalls as you like. your router itself, with network address translation, also acts as a firewall. with windows, if that's what you're using, you need all the protection you can get.
17-05-2008 3:05 PM
Thanks for that , just didn't want to do anything that may cause any problems when everything is working ok.
