RouterStats and other similar programmes
I just seen RouterStats refered to, and had a quick look.
Does this monitor the circuit as long as its running ?
does it work with the Thomson 585v7 router ??.
any other similar open source programmes ?Huh
Fixes: 62
Re: RouterStats and other similar programmes
Yes - it monitors continuously
http://www.vwlowen.co.uk/internet/files.htm
Speedtouch 585 v6 & v7 but you can't fiddle with the noise margin
Thanks Jim,
I find it rather strange that people aren't advised to use this more - or have it missed it ?Huh
Fixes: 62
You have missed it  Grin - I won't suggest using the Forum Search command because as we all know that is really dire.
Quote from: Oldjim
Do you mean continuously while routerstats is open and running or is there something I missed?
Fixes: 62
Exactly
Obviously if you close it - it stops
Ok that is what I thought you meant.
