RouterStats and other similar programmes
- RouterStats and other similar programmes
10-02-2009 4:07 PM
I just seen RouterStats refered to, and had a quick look.
Does this monitor the circuit as long as its running ?
does it work with the Thomson 585v7 router ??.
any other similar open source programmes ?
6 REPLIES 6
Re: RouterStats and other similar programmes
10-02-2009 4:10 PM
Yes - it monitors continuously
http://www.vwlowen.co.uk/internet/files.htm
Speedtouch 585 v6 & v7 but you can't fiddle with the noise margin
10-02-2009 4:17 PM
Thanks Jim,
I find it rather strange that people aren't advised to use this more - or have it missed it ?
10-02-2009 4:38 PM
You have missed it - I won't suggest using the Forum Search command because as we all know that is really dire.
10-02-2009 6:37 PM
Do you mean continuously while routerstats is open and running or is there something I missed?
Quote from: Oldjim Yes - it monitors continuously
10-02-2009 6:47 PM
Exactly
Obviously if you close it - it stops
10-02-2009 9:30 PM
Ok that is what I thought you meant.
