Router
kitkat
Router
I am sorry if this is the second time I have posted this same question. I wrote one at 2 o'clock this morning but was half asleep at the time and don't think I pressed the post button. Anyway my question is, I am going away shortly for 3 weeks . Should I switch off the router until I get back home? Smiley
3 REPLIES 3
Chris
Legend
Fixes: 169
Re: Router
It shouldn't really make a huge difference. If you do want to turn it off I'd suggest logging in to the router and pressing the 'disconnect' button before powering down. When you get back try to power it up in daylight hours.
kitkat
Re: Router
Thank you Chris.
Anotherone
Champion
Fixes: 21
Re: Router
And when it's booted don't forget to log on and click Connect Wink
