Router + reverse proxy (a question for webmasters and server experts)
mrspock
I'm having my personal site hosted home, on a RPi 4 server and it's working great. The plusnet router forwards the thhp/s ports to the local RPi. Now, I'd like to host another RPi server with another domain on it, and from my knowledge it can either be done through a reverse proxy server, because the plusnet router forwards ALL http/s requests to a single lan address (ie my current RPi 4).
The question is (because I don't want to have a chain of RPis connected as a reverse proxy + 2 servers), is there a router that has a reverse proxy server in it? Therefore a router that will 'know' to redirect to the proper local server when a certain domain will be typed in the browser's address bar.
Ideally my home network will be made of the ROUTER   >  RPi SERVER, where on the server will be 2 different working domains, both public and accessible on http/s without having to type extra port numbers (such as domain1.com:1234, domain2.com:1235), but I don't know if such router even exists. Google is either becoming dumber or more advanced to display proper results to my Qs.
2 REPLIES 2
7up
Legend
Fixes: 17
Re: Router + reverse proxy (a question for webmasters and server experts)
Why use multiple RPis? - Why not just use Apache's built in virtual hosting instead? - That lets you setup multiple hosts / sites with just one instance of apache running to serve them all.
Unless you have a real need for your sites to be on different physical hardware, i'd go with the VH option.
mrspock
Because RPis are not strong enough to host multiple Wordpress sites, and I'd rather use more RPis (one per site) than a bigger and more performant server.
