Router recommendations
Trapper_Dave
I'm looking at getting a new router. I'd like to make a wireless network including connection to an Xbox 360. Does anyone have any recommendations at all?
Edit: I currently have a Belkin F5D7632-4uk router, but it's irritating me beyond all belief. It locks up and says that it's connected to the internet even when it isn't.
RobDickson
Re: Router recemmendations
Shouldn't this be in the "Wireless Broadband" section?
Anyway, I use Linksys hardware, and find it works fine.
VileReynard
All Star
Fixes: 11
Quote from: Trapper
The question presupposes that you have an old router?
Denzil
The Netgear DG834G is often recommended here.
ed
Re: Router recommendations
I've been through a few..
DLink set on fire
Netgear had trouble with interference from XBox Wifi Controller
BT Voyager 2110 performance is as solid as a rock, but It's pig ugly to look at. Smiley
Trapper_Dave
What problems did you have with your Netgear and Xbox WiFi adapter? As I've ordered a Netgear for the very reason of turning my Xbox 360 to WiFi.
ed
Not a problem with Wifi adapter (mine was hard wired), a problem with Wifi joysticks using Voice over IP!
My PC laptops would crawl when ever anyone was using the XBOX 360
Who needs a wireless joystick that has enough strength to play from the garden!
