Router Advice
Eggs
Router Advice
http://www.ebuyer.com/368777-linksys-e2500-wireless-n600-dual-band-cable-router-e2500-uk
Is this compatible with Plusnet FTTC fibre optic?
... and what do people think of it?
2 REPLIES 2
Steve
Seasoned Pro
Re: Router Advice
Hello take a look at this thread from this forum click the link  http://community.plus.net/forum/index.php/topic,129313.0.html/
or this one  http://community.plus.net/forum/index.php/topic,116470.0.html
Regard's
If life gives you lemons, make lemonade.
HairyMcbiker
All Star
Fixes: 21
Re: Router Advice
It should be compatible but you will still need the BT modem.
