Router Advice Needed
thesign
Hello Everyone,
Right now I have a 4 port (wired) linksys AG241, this has been a good router but no longer suits my needs (more computers, static IPs).
I am looking for a wired ADSL router with 6+ ports that can also point my 5 static IPs from PN to different computers on my network (sorry, I don't know the correct tech term for that Tongue). If I could find something similar to the linksys I have right now, but with the extra features, that would be great.
Any suggestions would be greatly appreciated, thanks Smiley
Re: Router Advice Needed
Keep the router, add a  5 or 8-port switch.
PS The tech term you don't know - It's called routing, that's what routers do. Yours too, most likely.  Wink
MrC
As HPsauce says you can add an additional switch to connect more devices. You can use NAT forwarding to direct ports or ranges of ports to specific devices on your internal LAN - a quick check of the user manual for your AG241 shows it's under Applications & Gaming. Or you can disable NAT altogether and just let your router route, although there are some security implications which you need to be aware of here.
VileReynard
Seasoned Pro
Fixes: 9
http://ask-leo.com/whats_the_difference_between_a_hub_a_switch_and_a_router.html
Should explain what you need (except that they don't make hubs any more as switches can do a similar job).
itsme
Quote from: thesign
Hello Everyone,
Are you using public static IP's on the AG241 at the moment and if so how have you configured the router?
