Router ADSL Phone Line Setting
Strat
Fixes: 565
Not a problem but I noticed this setting on my Billion router.
Phone line pair Inner pair   Outer pair
I can select one or the other but I haven't done so. It just looks very puzzling considering there is only the one phone line socket on the back of the router Huh
4 REPLIES 4
chenks76
All Star
Fixes: 12
Re: Router ADSL Phone Line Setting
it'll be referring to which pair of wires on the actual cabling/wire that is being used i would assume.
Strat
Fixes: 565
But that would be a physical change inside the NTE.
Not something the router would know about or have any control over Undecided
Mustrum
Fixes: 81
Seems its a reserved setting according to the manual.
Possible the designer thought he could tweak settings perhaps on a longer line depending on the pair used, then later realised it was a tweak too far, or needed the code for some other feature.
RobPN
Fixes: 15
Quote from: Strat
Quite likely referring to which pair of the RJ connector are used for the incoming telephone line.  Some countries use the inner, some the outer, and a 2-line setup (e.g. USA) can use both the inner and outer pairs for lines 1 + 2.
