Root
Root
04-11-2017 12:23 PM
There are a number of programs that allow rooting of your device but is there one that stands out above the rest ?
Can rooting your device have any affect on apps already on your device ?
Re: Root
04-11-2017 12:38 PM
Well I know my bank app (Barclays), warns you on a iPhone that it won't run on jailbroken ones.
No I haven't tried it
I would imagine it would depend on the app and whether they have put something in to detect it. Persumably they could put a check in which would otherwise fail on a more restricted device, but if it then works then refuse to run.
Re: Root
04-11-2017 1:23 PM
Whatever device I'm messing about with my usual first port of call is to look on the XDA Developers forum here
Last device was a very cheap Nook HD+ which makes a nice standard 9" android tablet with a full HD display with the help of cyanogenmod
Not bad for £9
Re: Root
04-11-2017 2:38 PM
As to specific apps to root, nope depends on the unit, somethings work on some and not on others.
Re: Root
05-11-2017 2:44 PM - edited 05-11-2017 2:54 PM
Yes if you can get hold of a cheap device running the same OS - it may be worth getting one and having a play, just for the fun of doing it and see how it is. Then test what runs and what doesn't and the difference.
If it is your main phone, I would hold off doing it in case it breaks something (i.e. banking Apps) which I guess as Apps go, most of us have to use and depend on them.
I don't know about Android phones as have never had one of those, and whether the root changes can be reversed easily should it not go well.
Re: Root
07-11-2017 7:42 AM
Re: Root
17-12-2017 4:24 PM
Firstly what do you gain to benefit from it?
Yes it might be good fun and a laugh to do it, but otherwise.
If your bank apps stop working how much of a pain would it be for yourself, and then looking for solutions to make them work.
It it were me, I’d pick up a cheap Android test device and do whatever you want to it and don’t touch your main phone until you’re confidient it works in the way you want.
Re: Root
17-12-2017 6:07 PM - edited 17-12-2017 6:10 PM
When I first rooted my phone the objective was to get rid of junk and be able to fully back up and reinstall programs/data. Other things like the Nook it's to turn it into a standard android tablet and the Hudl get rid of Tesco.
As for some apps stopping working I've not seen that myself but I have seen some "roots" that come with an on and off option.
Re: Root
04-10-2019 11:49 AM
I've also got a rooted Nook HD+, running a Cyanogenmod version of Android 4.4.4. It is somewhat flaky at times, rebooting itself at random. I don't know if this behavior is OS or hardware related. What version are you running?
Re: Root
04-10-2019 4:58 PM
I have 4.2.2 on mine. Seems pretty stable with just the odd rare bit of bad behavior.
Though I guess this is probably down to what you are trying to run as the hardware can't be what the software is expecting.
