Attempting to remove ADAuditplus from a vista home premium on a full removal
It seemed to have stalled for approx 10 minutes, then came back with the above info, however it then continued to uninstall ADAuditplus
This is the 1
st time I have ever seen this after many years of using Revo
Have you ever seen this on the same or other programs you attempted to uninstall with Revo ??
Could this be a latest Revo version bug or an issue with Vista ?
System restore is turned on in vista
If that helps
