Retrieving Files
Retrieving Files
I can't access my browser or email on one of my PCs because of a fault.  I can access my program files.
I am using Firefox and Thunderbird.
I want to copy certain files to a memory stick so I can put them onto a new PC.
The main files I want are: address book, inbox, sent, drafts, all in Thunderbird and my URL history in Firefox.
Could someone please tell me which files to look at as I am confused when looking into the program files.
Thank you.
Re: Retrieving Files
It does depend on whether you're running XP or Vista.
If it's XP, you need to look under:
C:\Program Files\<your username>\Application Data\Thunderbird
if it's Vista, you need to look under:
C:\Users\<your username>\Application Data\Thunderbird
You will see a Profiles folder, a profiles.ini file and a registry.dat file.
Take a copy of all of these, and place onto another machine in exactly the same place.
For Firefox, take a copy of:
C:\Program Files\<your username>\Application Data\Mozilla Firefox
Hope that helps
B.
Quote from: Barry
Thanks Barry. That will be a great help.
Quote from: artmo
Thank you.
Sorry to go back on this problem Barry, I should have given you this info originally.  I am wanting to load the details onto a PC with XP but want to retrieve it from an ME PC.  Can you help with what files I need to look for in ME.  Thank you.
prichardson
The following Mozilla Knowledge Base section should advise the locations associated with appropriate systems.
http://kb.mozillazine.org/Profile_folder
simple solution is to get Firefox/ thunderbird backup from
http://mozbackup.jasnapaka.com/
Its free and will backup up all the file and then use it on the new pc to restore them. It does extensions, passwords  as well
Thanks guys for the suggestions.  I will give them a try.
