Reset Thomson wireless router password/username
bulb
Hi all
Does anyone know how to reset a Thomson Wireless router username and password?
I forgot them so now i cannot access the web interface of the router
CHeers
VileReynard
Seasoned Pro
Fixes: 11
Re: Reset Thomson wireless router password/username
You could reset to factory settings.
pierre_pierre
you might have said how to do that.  near the power plug on the back is a small hole, insert a blunt point and hold down for say 10 Seconds, that will reset to factory, you will then have to insert your username and password to log back in to PN
bulb
Thanks Both Smiley
