Reporting server abuse coming from a Plusnet IP
SteveA
A week ago I sent an email to abuse@plus.net concerning a compromised machine which is running some pretty stupid malware.
It went quiet for a week but its back on the same IP address which suggests either the machine has got re-infected or its cycling round a list of targets.
I've put a .htaccess rule in to block it but obviously the machine is still compromised
The logs it's leaving behind look like this:
[tt]212.159.xxx.xxx - - [31/May/2015:10:46:56 +0100] "GET /Ringing.at.your.dorbell! HTTP/1.0" 403 306 "http://google.com/search?q=2+guys+1+horse" "x00_-gawa.sa.pilipinas.2015" www.tty.org.uk
212.159.xxx.xxx - - [31/May/2015:10:46:57 +0100] "GET / HTTP/1.0" 403 282 "-" "x00_-gawa.sa.pilipinas.2015" www.tty.org.uk
212.159.xxx.xxx - - [31/May/2015:10:46:57 +0100] "GET / HTTP/1.1" 403 277 "http://google.com/search?q=2+guys+1+horse" "x00_-gawa.sa.pilipinas.2015" 127.0.0.1
212.159.xxx.xxx - - [31/May/2015:10:46:57 +0100] "GET /Diagnostics.asp HTTP/1.0" 403 297 "-" "x00_-gawa.sa.pilipinas.2015" www.tty.org.uk
212.159.xxx.xxx - - [31/May/2015:10:46:57 +0100] "GET / HTTP/1.0" 403 282 "-" "x00_-gawa.sa.pilipinas.2015" www.tty.org.u[/tt]k
7 REPLIES 7
bobpullen
Fixes: 316
Re: Reporting server abuse coming from a Plusnet IP
No harm in submitting another abuse report Steve. If it's still happening, then PM me the offending IP address and an excerpt from the logs and I'll make sure it's being seen to.
SteveA
I've sent another report in.
Steve
SteveA
Bob
I got a response from link:csa removed so hopefully the problem is now resolved.
Steve
adie:red removed CSA name as per link:rules]
SteveA
But apparently no-one did anything as exactly the same IP address was back on June 3rd doing exactly the same thing :
[tt]212.159.xxx.xxx - - [03/Jun/2015:11:56:39 +0100] "GET / HTTP/1.0" 403 282 "-" "x00_-gawa.sa.pilipinas.2015" www.tty.org.uk
212.159.xxx.xxx - - [03/Jun/2015:11:56:40 +0100] "GET / HTTP/1.1" 403 277 "http://google.com/search?q=2+guys+1+horse" "x00_-gawa.sa.pilipinas.2015" 127.0.0.1
212.159.xxx.xxx - - [03/Jun/2015:11:56:40 +0100] "GET /Diagnostics.asp HTTP/1.0" 403 297 "-" "x00_-gawa.sa.pilipinas.2015" www.tty.org.uk
212.159.xxx.xxx - - [03/Jun/2015:11:56:40 +0100] "GET / HTTP/1.0" 403 282 "-" "x00_-gawa.sa.pilipinas.2015" www.tty.org.uk
212.159.xxx.xxx - - [03/Jun/2015:12:14:23 +0100] "GET /Ringing.at.your.dorbell! HTTP/1.0" 403 306 "http://google.com/search?q=2+guys+1+horse" "x00_-gawa.sa.pilipinas.2015" www.tty.org.uk
212.159.xxx.xxx - - [03/Jun/2015:12:14:23 +0100] "GET / HTTP/1.0" 403 282 "-" "x00_-gawa.sa.pilipinas.2015" www.tty.org.uk
212.159.xxx.xxx - - [03/Jun/2015:12:14:24 +0100] "GET / HTTP/1.1" 403 277 "http://google.com/search?q=2+guys+1+horse" "x00_-gawa.sa.pilipinas.2015" 127.0.0.1
212.159.xxx.xxx - - [03/Jun/2015:12:14:24 +0100] "GET /Diagnostics.asp HTTP/1.0" 403 297 "-" "x00_-gawa.sa.pilipinas.2015" www.tty.org.uk
212.159.xxx.xxx - - [03/Jun/2015:12:14:25 +0100] "GET / HTTP/1.0" 403 282 "-" "x00_-gawa.sa.pilipinas.2015" www.tty.org.uk
212.159.xxx.xxx - - [03/Jun/2015:12:14:26 +0100] "GET / HTTP/1.0" 403 282 "-" "x00_-gawa.sa.pilipinas.2015" www.tty.org.uk
212.159.xxx.xxx - - [03/Jun/2015:12:14:26 +0100] "GET / HTTP/1.0" 403 282 "-" "x00_-gawa.sa.pilipinas.2015" www.tty.org.uk[/tt]
So did the CS representative actually do anything?
bobpullen
Fixes: 316
The owner of the IP in question was contacted on the 2nd. Have there been any further instances since the 3rd?
SteveA
Not that I've seen but it seems to be several days between hits.
bobpullen
Fixes: 316
Drop me another message if you notice it again.
