Replacing plusnet hub with modem/router
petercons
I've used a modem/router successfully at a previous address (but that was direct to exchange and not Plusnet -SoGEA)
At the new address my Vigor v120 V2 modem just tries to handshake and then goes back to ready (shown with a PC attached). The PPoE login credentials are only on the router and the logging on that just shows a failure to connect and no detail.
I'm using the same rj11 cable and filter to the modem as I am to the Plusnet hub. The modem firmware is the latest available and the configuration is default- PPoA which passes the PPoE packets to the router.
My work around currently is to use the Plusnet router as a modem to my Netscreen/Juniper router.
Plusnet tech support logs only show the Plusnet authentications and no failures.
If you happen to think of anything I can try then please let me know. Thanks.
3 REPLIES 3
Fixes: 585
Re: Replacing plusnet hub with modem/router
@petercons
The Vigor 120 is an ADSL only modem. SoGEA is a VDSL product , so you need a VDSL modem.
Are you using the Plusnet router in its default (router) mode ?
It's possible to use it as a modem only by setting bridging mode, which will make it similar to the Vigor 120 but VDSL capable
RealAleMadrid
Fixes: 68
@petercons  If you have a Plusnet Hub2 that can be configured in bridge mode so it acts like a separate modem as @MisterW  has suggested.  The earlier Plusnet Hub1 cannot be set to bridge mode.
petercons
Many thanks for your suggestions and advice. I will try the plusnet in bridged mode..
