Replacing Vaio battery
- Replacing Vaio battery
04-08-2012 11:04 AM
I have found this at £29.99 with delivery at £4.99.
One thing worries me, though, and that is I cannot find a UK address or telephone number on their site and it seems batteries are shipped from Hong Kong. The latter part wouldn't be a problem if there was a UK contact.
Has anyone used these before or can you recommend a laptop battery supplier?
There's also some here ranging from just over £40 to just under £50.
Any advise on purchasing the battery would be appreciated as this is new territory.
Forum Moderator and Customer
Re: Replacing Vaio battery
04-08-2012 2:50 PM
04-08-2012 3:46 PM
As AlaricAdair says.... it may "fit" the laptop, but not necessarily be fit to work it in the same way as the original... you need to look at the battery specification ( on the battery label) and get a match to them.... If you are unsure, contact the supplier, and ask them to confirm that it is a "direct replacement" for your particular machine.....
04-08-2012 7:35 PM
I've used these details along with the model no to search on Google.
My main concern is finding that 'reputable' dealer.
23-08-2012 9:06 PM
23-08-2012 10:31 PM
http://www.laptop-power.co.uk/laptop-batteries/?gclid=CI2openY_rECFc93fAodoj8AzA
Head Office | Laptop Power (NW) Ltd, Alchemy Industrial Estate - Unit 6,
Platinum Court, Alchemy Way, Knowsley, Liverpool, L33 7XN
See what comes up ! ! !
26-08-2012 11:51 PM
