Replacing Netgear DG824GT
ah
This router works very well.  I need to buy another one, similar, to use in another location and I guess that there are new models out now. Which one would you advise me to buy, please
8 REPLIES 8
chenks76
All Star
Fixes: 12
Re: Replacing Netgear DG824GT
the DG824GT is quite old, and will have been superseded many times over.
however, i'm sure you could pick up a DG824GT very cheaply on ebay if you want to stick with what you know.
without knowing what your specific requirements are it's impossible to even hazard a guess at to what to recommend.
ah
I don't want to stick with what I know.  My requirements are that I need something similar but more up to date
chenks76
All Star
Fixes: 12
based on the vague response, all i can say then it get the current netgear equivalent of the DG824GT
ah
Yes, but how can I know which is the current equivalent of the GD824T, please?   I'd like to be more precise but I just don't know what precisely you need.  I need a WiFi router as fast as possible
chenks76
All Star
Fixes: 12
how many ethernet ports do you need? and what speed?
what spec of WIFI do you need?
is it for ADSL or FTTC?
do you need lots of advanced settings?
SpendLessTime
Aspiring Hero
Fixes: 86
@ah
Go across to kitz's website forum, I'm sure you will find someone there with indepth knowledge yo to help you http://forum.kitz.co.uk/index.php/board,5.0.html
ah
I don't need many ethernet ports since I connect on WiFi. Most of the routers have 4 and that's fine with me, just to connect with a cable in case I have WiFi problems.
About the speed I presently have 9.3Mb/s upload and 0.99Mb/s download. It is very low and I don't know if this is due to my location (central London - Chelsea) or my Plusnet subscription (plusnet unlimited).
It is for ADSL
No I don't need lots of advanced settings.
The whole story is that I want to move this router to the Alps to replace an old Netgear 824M that needs rebooting very often but I don't know if this is due to the router itself or to the service provided.  I'll find out when I change router.
ah
Thank you SpendLessTime for the link.
