Reopen Last Browsing Session - IE8 W7 32
Mav
Fixes: 515
After installing the latest Windows updates I forced a restart expecting all the tabs on IE8 to reopen but only one of them did.
(I use FF but SWMBO uses IE and I have lost her last session.)
Is there a setting somewhere I have missed to ensure it opens all previous tabs or does it simply not work the same way as FF?
Forum Moderator and Customer
2 REPLIES 2
ReedRichards
Seasoned Pro
Fixes: 25
Re: Reopen Last Browsing Session - IE8 W7 32
IE does not store open tabs in the way that Firefox does.  You'll have to try to use the history.
Mav
Fixes: 515
Thanks for clarification.
