'Renaming' links
Legend
Fixes: 232
'Renaming' links
I know this has been asked before (I think I did on the old SMF forums), but how do you turn say a link to this post into a one or two word hyperlink on these new-fangled boards?
7 REPLIES 7
HairyMcbiker
All Star
Fixes: 21
Re: 'Renaming' links
If you use the full editor (not the quick reply) then press the chain button on the toolbar, in the 2nd box put the text you want
Legend
Fixes: 232
So that replaces the 'globe' thingy on the old SMF boards?
Thanks @HairyMcbiker
Legend
Fixes: 232
Right, thanks @HairyMcbiker, I've just done my first post after following you help, but found a small problem.
When I've renamed the link, I want to 'lose' that tag, so I can continue with normal text, but I don't seem to be able.Huh
I'm sure there must be a way, but I can't find it.
Sorry for seeming thick.
HairyMcbiker
All Star
Fixes: 21
Yep seems hit an miss.
I tend to use
"name I want to use"<SPACE> select the "name" part and use the link as before, the trailing space usually stops the link overflowing, failing that a CR then a BS works as well.
Legend
Fixes: 232
Thanks, I'll have a go with that next time I need it - if I can remember.Wink
Mav
Fixes: 512
Click in the linked text then again on the Chain icon then delete the URL from the box and press OK.
Forum Moderator and Customer
Legend
Fixes: 232
@Mav Noted for the future, thanks - just hope I can remember it.Wink
