Removing unwanted apps in Win10
- Removing unwanted apps in Win10
05-08-2015 11:21 AM
Re: Removing unwanted apps in Win10
05-08-2015 11:29 AM
05-08-2015 3:36 PM
05-08-2015 8:28 PM
http://www.techpowerup.com/forums/threads/windows-10-tweaks.214172/
06-08-2015 7:07 AM
06-08-2015 8:05 AM
Now let's see what else I can remove
07-08-2015 2:59 PM
I just knew it would be a BIG mistake downgrading from Win7 to Win10.
11-08-2015 7:06 AM
11-08-2015 9:01 AM
That's it! Note that in Windows 10, the Store app can be uninstalled. See How to restore Windows Store in Windows 10 after removing it with PowerShell.
Also, some apps cannot be uninstalled like the Contact Support app, Cortana, Photos, Microsoft Edge, Windows Feedback app and of course the Settings app
Also, the Store app made its way back to my system via some update.
So , after doing all that work..... it comes back to haunt you again in the famous "automatic update installs" for your safety and benefit, as supplied from Microsoft....
My Bold and type size "improvements"....
11-08-2015 9:23 AM
Quote from: shutter @ RR..... very interesting.... and anyone would think....... Ah Great...!... I`ll spend some time doing that.and stop all these annoying things.... until you get to the last paragraph...
[snip]
Quote So , after doing all that work..... it comes back to haunt you again in the famous "automatic update installs" for your safety and benefit, as supplied from Microsoft....
Yes, precisely, and that's one of the reasons why I've gone back to Win7 on my main PC.
11-08-2015 9:55 AM
I got annoyed with Cortana as it is something i will never use and do not want so i manualy got rid of it and it seems to not come back now.
11-08-2015 10:10 AM
The ones it says you cant uninstall ,, Simples you dont use them
Just because you cant uninstall does not make win10 bad
11-08-2015 10:50 AM
Quote from: rongtw The ones it says you cant uninstall ,, Simples you dont use them
Not so seemples; I got the link I quoted from someone who asserts that some of these apps run unbidden and consume a good deal of the computers resources so his computer ran faster without them.
11-08-2015 10:56 AM
11-08-2015 11:01 AM
