Remote access software
- Remote access software
25-11-2013 10:13 AM
My brother's laptop runs windows 7, my old faithful runs XP but I could use my wife's laptop on windows 7 if required. I would need to be able to create folders for email, move stuff around, help with configuring bits and bobs, basic stuff really.
Any suggestions appreciated.
Re: Remote access software
25-11-2013 10:25 AM
25-11-2013 10:26 AM
Also has an iPhone app.
25-11-2013 10:51 AM
@Alex - we did register for the free trial of logmein, installed it but didn't have cause to use it in the 3mths or whatever the trial period was and then promptly received an email saying the trial period had expired !, not sure if they do a permanently free home user version now?
25-11-2013 11:48 AM
I use it on my server here - was handy to have a backup means of access when I was playing with port forwarding and killed my remote desktop connection
It's used by the sysadmin at work too - I think the main limitation of the free version is you can't transfer files.
25-11-2013 12:37 PM
Logmein is okay but we moved away from that in favour of teamviewer.
Norton had one as well (PCAnywhere), not used it in years though (rubbish)
25-11-2013 11:17 PM
26-11-2013 10:11 AM
Can you use remote assistance on Win 7 home edition or do you need pro?
26-11-2013 11:20 AM
26-11-2013 12:15 PM
Works very well in my experience.
It also supports pretty much any OS, including XP.
26-11-2013 2:12 PM
I've been using it for many years including accessing several remote machines in different locations at the same time. There is a limit to 10 remote machines, though. I have just reached that limit but I don't envisage requirements for more.
Forum Moderator and Customer
26-11-2013 9:19 PM
Quote from: rja66 Can you use remote assistance on Win 7 home edition or do you need pro?
I use remote assistance between pro (64) and home (32) edition, works well, both systems have multiple monitors all monitors are shown.
26-11-2013 10:54 PM
Quote from: Strat I have W7 Home Premium and have used Remote Assist.
Likewise. Recently I used it from my Windows 7 Home computer to another Windows 7 Home computer a few hundred miles away. It was very easy to set-up.
28-11-2013 3:52 PM
28-11-2013 4:10 PM
