Relocating NAS Drive
- Relocating NAS Drive
09-05-2015 4:47 PM
I have an 8 port TP-Link switch behind there and having just looked....it's full
For goodness sake I don't run a server farm behind there but it means I need to increase ethernet port capacity.
I have looked at doubling up on 8 port switches or getting a 16 port switch. I would prefer a single unit and mains brick behind there but the cost of a 16 port switch seems to be way more than double the cost of an 8 port unit.
The TP-Link 8 port is £18
Unless someone knows different?
Re: Relocating NAS Drive
09-05-2015 5:52 PM
http://www.ebay.co.uk/itm/381087334057
Gigabit is more though, but unless you're streaming to multiple TVs at once, 10/100 should suffice...
09-05-2015 5:54 PM
I occasionally transfer large amounts of data across my network as I am at present so the quicker the better.
09-05-2015 6:03 PM
09-05-2015 6:05 PM
09-05-2015 6:11 PM
http://www.ebay.co.uk/itm/151216567411
Though you'd need to make sure the barrel plugs are of the right size for the job...
09-05-2015 6:14 PM
09-05-2015 6:19 PM
09-05-2015 6:33 PM
09-05-2015 6:42 PM
That said I've also got network cables all over too, really do need to consolidate stuff in here, starting to look like the inside of a borg cube with all the cables and wires & flashing green lights...
10-05-2015 10:43 AM
10-05-2015 11:41 AM
But yes, ebay specials are a no-go, you never know how badly they've been made, and to what level of cheapness...
10-05-2015 9:06 PM
I was out at the time but my daughter let them in and while fitting 2 alarms they commented on my trailing sockets, telling my daughter that such things were quite dangerous and should be removed.
11-05-2015 8:03 AM
The only unsafe way of using them is if they're operating high-current appliances, the cheaper sockets (and their cheap plastic plugs too) tend to melt with the heat generated by the current resulting in a potential fire situation, but that's only an issue if the end user's an idiot and is fodder for evolutionary natural selection...
If I have to use a trailing extension for something high-current, I use proper urea-formaldehyde plugs & sockets (better at resisting breaking down under heat), 2.5mm 3-core cable, and if necessary, an RCD device on one end, it's only logical to do so...
11-05-2015 11:30 AM
personally I have half a dozen 4 or 6 way switched surge protected (voltage regulating type) extension bars, being a new property this one has several double sockets round the lounge but in the area designated on the building plans as "tv area" there is only 1, the people making the building 5 years ago didn't expect anyone to have a console, skybox, surround sound unit, disk player and tv......
in the area designated as "office space" there are 2 double sockets and the nte5 face plate, so not even enough to plug in the phone, router, modem, monitor, tower, usb hub, nas box, desktop lamp, phone charger and so on..... result is 3 six way switched extension bars to plug in all the stuff at the desk, or as I have it now, 1 UPS with 6 outlets one of which is a 4 way power strip for the phone/ modem/router/usb hub both monitors the tower the nas and a few other devices I don't want to suddenly loose power, and 2 6 way switched power strips ....
the fire service gives out advice that changes regularly just like wiring regulations and rarely has anything to do with common sense, decent power strips present a hazard in areas where dust builds up, simple answer hover once a week ....
