Reinstall win 10
- Reinstall win 10
Re: Reinstall win 10
24-04-2019 2:22 PM
Is it a modular type PSU? Got a model number?
24-04-2019 2:27 PM
24-04-2019 2:51 PM
Assuming the PSU and major bits are OK, do the individual connectors such as SATA power etc look OK?
Also no possible shorts or overloaded 4 pin Molex style connectors?
24-04-2019 6:22 PM
24-04-2019 8:23 PM
25-04-2019 8:11 AM
@penfold wrote:
The refurb unit was a good price, and from a reputable manufacturer.
In the context of computer equipment, "refurbished" means second hand and briefly checked to see if it still works. If your PSU took 30 seconds to fail then that may be too long to be caught by the check.
25-04-2019 10:18 PM
25-04-2019 11:29 PM
Dosnt explain why psu was cutting out my sons though.
I have to agree. Though I'd of thought the PSU would have short circuit protection, so even if the new MOBO was shorting it out, I'd expect it to have worked in your sons. If it doesn't have short circuit protection then it's possible a capacitor or two (or other electrickery) might not have liked it.
Got to admire your honesty, many wouldn't have 'fessed up'.
(and yes, I'd let on if I'd done the same)
26-04-2019 12:13 AM
Maybe the BIOS initiated the shutdown, causing the PSU to switch off?
Some protection mechanism must have been invoked, somewhere...
26-04-2019 5:08 PM
27-04-2019 8:40 PM
28-04-2019 2:41 PM
As we thought earlier then, as it didn't work in both PC's (and now you've sorted the MOBO), the new PSU is working, so hows the install of W10 going/gone?
28-04-2019 4:00 PM
28-04-2019 4:59 PM
From the bios screen, have you altered the boot order?
(as you're making a bootable USB, make sure you open the files and then move them to USB, if you put the main file on only, it won't (IIRC) boot from it until you open that file and then put that content (various files) on it)
28-04-2019 5:11 PM
What a faff this has been. Never had so much trouble with building a pc.
