Reformat Vista
- Reformat Vista
Reformat Vista
22-03-2011 6:22 PM
Just reformatted a laptop and the recovery disk gave two options:
Recovery to Factory Default (all files lost)
Fail-safe recovery - this action will restore your computer back to original NB Manufacturer's setting. All files and settings will be
lost. Are you sure that you want to continue?
Please does anyone know what the difference is? BTW I chose the first option.
8 REPLIES 8
Re: Reformat Vista
22-03-2011 6:40 PM
I think it would be that option 1 would do a wipe and a type of "ghost" image restore - back to when you first got the l/t, the 2nd would do a re-install trying to "fix the problem" (if it isn't a virus etc)
But some of the Linux haters will probably tell me I am wrong and shouldn't post in here
Re: Reformat Vista
22-03-2011 6:51 PM
you will probably find that factory hasnt got the drivers for some of the bits fitted
Re: Reformat Vista
22-03-2011 7:02 PM
I am sure that you are very welcome in the Windows forum HB!
Yes, Pierre I had a thought that a driver-less restore might be the result of the second, in which case what a good job I chose the first.
Should be a bit more explicit though.
Re: Reformat Vista
27-03-2011 11:10 AM
Quote from: poppy Just reformatted a laptop and the recovery disk gave two options:
According to the manual here http://www.scribd.com/doc/7415279/Recovery-Manual-English the first option restores from a hidden partition on the hard drive whilst the second option restores from a DVD and deletes that hidden partition as part of the process. Presumably the hard disc gets completely reformatted in the fail-safe option.
Re: Reformat Vista
27-03-2011 11:27 AM
Thank you RR for taking the trouble to source that document, enabling me to understand it better. I will bookmark it in case I need it again. The computer does not have a hidden partition, only C: containing the OS and a 10GB 😧 partition which is empty. Had I proceeded with the second choice I would have ended up with just one C: partition which would not have been a problem. However, glad to have chosen the first. as it was very simple indeed, other than taking hours to get the updates.
Re: Reformat Vista
27-03-2011 3:08 PM
Quote from: poppy ......... The computer does not have a hidden partition, only C: containing the OS and a 10GB 😧 partition which is empty.
So where did the recovery data come from?
Re: Reformat Vista
27-03-2011 8:14 PM
Not sure if they still provide them but my MSI came with a recovery DVD which presented me with the options as referred to above. Have bought 3 of these laptops (not all for me I might had) and none of them came with a recovery partition. I wish that other manufacturers did the same instead of having to make your own when the machine is new.
After all, recovery partitions are no use if the HD has failed.
Re: Reformat Vista
27-03-2011 10:25 PM
So I correctly identified that it was an MSI laptop (as per the instruction manual I found) but it seems that in your case there was no recovery partition; whichever option you chose there was only one possible result.
