Referrals through Quidco - aknowledgement times ?
- Referrals through Quidco - aknowledgement times ?
01-04-2012 4:48 PM
Hi.
I have done a couple of referral setups through Quidco, both are active and running, one from 6th Feb so i would have thought it should be ok by now but not had any feedback from Quidco?
cheers
cheers
2 REPLIES 2
Re: Referrals through Quidco - aknowledgement times ?
02-04-2012 11:41 AM
Hi blackrat999,
In the first instance I'd say drop Quidco a line. They're normally quite responsive, so see what they come back with.
Jojo
Jojo
02-04-2012 1:23 PM
Thanks i have given it a go - not too hopeful as the oldest one wasnt tracked at all (despite my best efforts!) and the one that was they are asking for all sorts of reference numbers when i would have thought the username would be more than enough to verify.
anyway have posted re the one claim and will add the second when they reply and report back - thanks
Richard
Richard
