Redo
Redo
11-02-2016 3:35 PM
Has anyone used redo backup and restore to to copy dual boot system, linux & windows.
I ask because the program has not been updated since november 2012 and the posts in several forums regarding that question are not that clear.
Sure I could have a go but don't want to mess up a system that works ok.
We are born into history and history is born into us.
2 REPLIES 2
Re: Redo
11-02-2016 4:15 PM
Quote Redo doesn't need Windows. Download and burn the ISO, place it in your CD-ROM drive, and reboot your machine.
The system will load a complete mini operating system with a point-and-click user interface into your computer's memory, without writing any information to your hard drive.
Then you will be able to perform backup, restore and recovery actions—guaranteed—even if you aren't able to boot into your regular operating system.
Redo Backup and Recovery is a GPLv3 Perl script built with a GTK2+ interface designed in Glade.
It is simply a front end to partclone, which performs the actual backup and restore.
The live CD is built on Ubuntu to provide a graphical user interface and unmodified binaries of each program,
but the script will run on any Linux platform that has the required programs installed. The Perl source code for the backup script is contained on the live CD itself
So redo is just a script which runs a GUI which runs the backup.
So updates are likely to be rare.
Re: Redo
11-02-2016 11:45 PM
Thanks,
That leaves me a bit wiser regarding the lack of a need for it to be updated but it would be useful to hear from anybody who has used it to copy and then restore a dual boot system.
