Recycle bin
- Recycle bin
Recycle bin
02-04-2010 6:57 PM
The box remains empty; I cannot find the deleted item via Search so assume the box has been by-passed.
The by-pass facility in Recycle Box 'Properties' is unchecked.
Can I cure this fault?
Is my 6 year old computer breaking down?
Help and/or comments appreciated.
Tony.
Re: Recycle bin
02-04-2010 7:20 PM
You should see something like this - is there space available
Re: Recycle bin
03-04-2010 9:10 AM
Re: Recycle bin
03-04-2010 9:39 AM
I get 'Global' and 'Local disc' when I select properties.
Local Disc shows size of drive152GB, space reserved 3.99GB.
Tony.
Re: Recycle bin
03-04-2010 10:57 AM
Do you see this
Re: Recycle bin
03-04-2010 6:34 PM
Maximum size of R/Bin is currently set at 100%.
Local disc - size of drive:152 GB, space reserved: 3.99 GB
Re: Recycle bin
03-04-2010 6:46 PM
Reduce the maximum size to 10% and see if that helps. If not follow the instructions here http://support.microsoft.com/default.aspx?scid=kb;en-us;136517
Re: Recycle bin
04-04-2010 7:40 AM
Re: Recycle bin
04-04-2010 8:43 AM
I'll be back!
Re: Recycle bin
04-04-2010 9:04 AM
Re: Recycle bin
06-04-2010 8:51 AM
Thanks for your suggestions. Microsoft Support give a lot of information re: Recycle, but it dosn't seem relevant to XP. In any case, much of it is over my head!
I have in mind to upgrade my equipment this year; now maybe sooner than later.
Meanwhile, I'll have to be extra careful when I delete.
Re: Recycle bin
06-04-2010 9:51 AM
Re: Recycle bin
06-04-2010 6:31 PM
Alternatively, install a proper OS such as Ubuntu and get your Recycle bin included for free.
Re: Recycle bin
07-04-2010 6:32 PM
Thanks for the suggestions. I'll settle for the first one; I should be able to cope with that!
Then I'll think about Ubuntu.
I appreciate the responses of other members.
Re: Recycle bin
11-04-2010 10:22 AM
