Recycle Bin
Duncliffe
Recycle Bin
When I delete folders etc nothing goes to my Recycle Bin but disappears completely. The diversion facility is unchecked in Recycle Bin's "Properties".
This fault may have occurred after I updated Internet Explorer and intalled AVG.
Suggestions for action please.
Duncliffe
1 REPLY
Njal
Re: Recycle Bin
If you have multiple drives or partitions and there is a recycle bin on each make sure they are set up without the check.
Ensure Maximum Size of Recycle bin is not set to 0%.
See:
http://www.besttechie.net/forums/lofiversion/index.php?t5511.html
Regards,
Neil
