Recycle Bin not working as it should - W7
Fixes: 238
Whether I select delete from the file's menu or drag a file to the recycle bin the bin icon on the desktop still shows as empty.
Yet if I open the bin the files are there ready to be deleted and the icon then displays as full.
Sometimes Clicking on 'Empty the Recycle Bin' does nothing and I have to select the items and delete from the menu.
It doesn't matter from which drive I delete from.
Not a major issue but one I would like to solve if possible.
Forum Moderator and Customer
Fixes: 176
Re: Recycle Bin not working as it should - W7
http://www.winhelponline.com/blog/fix-corrupted-recycle-bin-windows-7-vista/
Customer and Forum Moderator. Windows 10 Firefox 64.0 (64-bit)
Fixes: 238
Thanks Strat.
I'll check that out a little later and let you know if it solves the problem.
