Recycle Bin not working as it should - W7
- Re: Recycle Bin not working as it should - W7
15-02-2011 10:20 AM
Whether I select delete from the file's menu or drag a file to the recycle bin the bin icon on the desktop still shows as empty.
Yet if I open the bin the files are there ready to be deleted and the icon then displays as full.
Sometimes Clicking on 'Empty the Recycle Bin' does nothing and I have to select the items and delete from the menu.
It doesn't matter from which drive I delete from.
Not a major issue but one I would like to solve if possible.
Forum Moderator and Customer
2 REPLIES 2
15-02-2011 11:03 AM
http://www.winhelponline.com/blog/fix-corrupted-recycle-bin-windows-7-vista/
15-02-2011 11:51 AM
Thanks Strat.
I'll check that out a little later and let you know if it solves the problem.
