Recurring changing Desktop Wallpaper
- Re: Recurring changing Desktop Wallpaper
15-05-2011 8:02 PM
15-05-2011 8:06 PM
15-05-2011 8:07 PM
For example Windows 7 includes it and for XP you should install http://www.microsoft.com/downloads/en/details.aspx?FamilyID=ce1d596b-6851-4948-ab76-b5ff22d37d69
15-05-2011 8:18 PM
(Judging by your answers so far.... it is between the two ! ! !).....
15-05-2011 9:31 PM
Quote This program will allow you to program a list of picture files to use as your desktop's wallpaper. These pictures will then be rotated through on a time interval that you assign. The pictures can be rotated in order (sequentially) or randomly. Version 1.0.0.24 may include unspecified updates, enhancements, or bug fixes
15-05-2011 9:35 PM
15-05-2011 9:39 PM
15-05-2011 10:09 PM
will have a look at the other one later... off to beddy byes now ! ..
15-05-2011 10:20 PM
Goodnight.
15-05-2011 10:44 PM
You can run it using pictures on your hard drive only and also you can block internet access via your firewall if you want - I did
http://www.webshots.com/page/apps and this FAQ answers most of the questions http://www.webshots.com/support/kb/Webshots_Software.html#19
Checking back in my Vista partition I see I used this one http://www.caledos.com/lab/Caledos/downloadC.aspx
16-05-2011 7:42 AM
16-05-2011 8:28 AM
16-05-2011 9:00 AM
Thanks Jim... (and artmo!)...
16-05-2011 9:03 AM
24-06-2011 11:04 AM
seeing another thread on here about XP REPAIR virus... I decided to run Malwarebytes (16 days since I last did one). and it has shown up that
"WallpaperSlidshowInstall.exe"
contains a malware... with the vendor listed as "Rogue.SystemSmartSecurity "
so I have done a removal and hope everything is (was) OK....
Webshots is still working fine... and I am very pleased with it...!
