Recording BT Sport
- Re: Recording BT Sport
Recording BT Sport
09-04-2015 7:10 PM
Hopefully I'm missing something here.
Am I right in thinking that if I get a Freesat PVR box I can record the channels it has access to?
And if I get a Sky box I can access BT sport in HD for £7.49/month with just a PN supplied card?
But I can't record BT sport - except perhaps without paying Sky for more than the cost of access to BT sport? Is there any workaround for this short of moving to BT for internet?
5 REPLIES 5
09-04-2015 10:04 PM
You need a Sky box to receive BT Sport. To record, you'll need a Sky subscription (or pay them for the Sky+ facility).
There isn't a Sky CAM module on Freesat boxes unfortunately.
10-04-2015 9:47 AM
Unfortunately, this is the only thing I can really suggest.
Apologies for this.
Apologies for this.
17-04-2015 8:36 PM
I have not tried this but it may work
http://www.amazon.co.uk/Hauppauge-HD-PVR-camcorder-satellite/dp/B00C22MGEM
23-04-2015 7:32 PM
Probably wouldn't work unless it stripped hdcp and if it did it wouldn't still be on sale on Amazon.
24-04-2015 10:21 AM
Thanks. I decided to just get Sky.
