Recommend me a mains networking kit please..
- Recommend me a mains networking kit please..
- « Previous
- 1
- 2
- Next »
Re: Recommend me a mains networking kit please..
05-12-2015 2:22 AM
05-12-2015 8:05 AM
05-12-2015 10:35 AM
05-12-2015 11:20 AM
Quote from: 7up Ah funny you mention that as I was mulling over fitting a mains cable to the garage...
I have TP-Link units linking to the garage. Local unit by the router is TL-PA4010, then two remotes model TL-WPA4220 one at the back of the house providing LAN to the desktop PC as well as wireless coverage, and one in the garage/workshop. I have to say they're very slightly flakey, with occasional drops in service for a few seconds or sometimes longer.
05-12-2015 11:39 AM
if your putting an ip cam on the end of an extension just buy a triple or quad socket header so you still get the 2 useable sockets and the camera/powerline adaptor don't take them both full time that way you get to use cheaper kit and still only have 1 hole through the wall
05-12-2015 1:35 PM
Quote from: Mook You may want to invest in a PoE version then and get a PoE camera as well. That way you can power the camera from the same source and not have to worry about batteries running out.
Ok so what advantage would I gain there over a mains cable using ethernet over mains? - The way I was thinking was just to fit the mains supply cable (which I', going to need for DIY out there anyway) and then just run the ethernet down that - where an IP camera can be both powered and networked at the same time.
I'm not really quite so sure that an ethernet cable will be able to provide enough juice for an angle grinder... or a possible welder in the future!
05-12-2015 1:44 PM
05-12-2015 2:04 PM
Quote from: 7up
Well the gain is obvious you don't need to run any cables, and you make no reference to running other tools from the mains cable you were thinking of running, you only make reference to a camera. Hence the sensible PoE option.
In fact I'll redact that in its entirety, including my original post while having considered the sheer stupidity of it. That so far no one has noticed!
05-12-2015 8:12 PM
With the mains wire being just one cable, I figured it would power my tools and carry ethernet at the same time but i couldn't quite fathom how an ethernet cable carrying a lower voltage and current would help.
The main point of this topic was purely for ethernet over mains for the inside of the house - but then nanotm reminded me of another issue that needed solving - the garage and with just one mains wire needed that can do everything it kinda makes sense to put that out there and let the ethernet come through that.
Unless there is an unknown flaw with the plan that i'm missing?
Quote from: nanotm the extension wont provide the juice for high amp gear either
Well it's always worked well for two sets of 500W floodlights and a drill OR angle grinder at the same time... so I don't think i'll need anything stronger than my trusty 13amp extension. That said i think it'll be more sensible to buy the cable itself rather than sabotage my extension reel - which i might need again in the future for something else!
05-12-2015 9:09 PM
05-12-2015 9:32 PM
most people don't run welding equipment off outlets below 30 amps because they heat tend to pulse draw the current and the trip switches get triggered when it appears to be a short circuit (which is what it is) and such a high fire inducing current is being called for/
05-12-2015 9:51 PM
05-12-2015 10:36 PM
Quote from: 7up ...not n#while i'm drilling or grinding!
Isn't there an app for that!
05-12-2015 11:13 PM
11-12-2015 6:46 PM
I went with these as to get me off the ground:
http://www.pcworld.co.uk/gbuk/computing-accessories/networking/powerline/netgear-xavb5221-100uks-pow...
Probably not the best or most reliable but for the money (peanuts) I figured they'd get me through for a while.
I'm still mulling over the others in case these are bad...
- « Previous
- 1
- 2
- Next »
