Recommend a wireless card
- Recommend a wireless card
- « Previous
- 1
- 2
- Next »
Re: Recommend a wireless card
16-04-2009 11:56 AM
If there are no options in the places you've looked then in a manual or specification or just possibly the manufacturers support software.
16-04-2009 1:05 PM
I have none of these available. As per the comments earlier, our IT support is not the greatest
I guess Plan B to purchase my own card to use would still be an option?
- « Previous
- 1
- 2
- Next »
