Rechargeable batteries.
- Rechargeable batteries.
11-04-2015 11:28 AM
I have three different sorts of rechargeable batteries which all charge ok, but over the course of a few weeks delete. So frustrating getting the camera out and finding that ALL the batteries, both in and out of camera, are flat.
I need AA batteries and a new charger may be a good idea too, as ours is about ten years old.
Any advice from experience would be appreciated thanks.
Re: Rechargeable batteries.
11-04-2015 11:42 AM
I would go for an intelligent charger which monitors each cell individually
This is what I bought http://www.amazon.co.uk/gp/product/B0071LH7EI?psc=1&redirect=true&ref_=oh_aui_detailpage_o01_s00
11-04-2015 11:51 AM
http://www.amazon.co.uk/Panasonic-2450mAh-Eneloop-BK-3HCCE-Battery/dp/B00JWC40JY/ref=sr_1_2?ie=UTF8&...
Edit :- Just noticed that Panasonic have taken over the brand name Sanyo.
11-04-2015 11:56 AM
11-04-2015 12:05 PM
That is what mine does and I just change the batteries when needed even when out and about
You can also stuff a pair of standard alkali batteries in instead in an emergency
11-04-2015 12:37 PM
Quote Low self discharge batteries keep their charge for much longer than normal NiMH batteries
11-04-2015 12:40 PM
11-04-2015 1:03 PM
If you want to check out which Eneloop battery is which and what it's capacity is, look at http://budgetlightforum.com/node/7336 which is the main source for information on all types of Eneloop batteries every made. Also tells you how to spot the fakes too.
11-04-2015 1:09 PM
11-04-2015 1:19 PM
A good reliable supplier, too.
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
11-04-2015 2:21 PM
11-04-2015 5:01 PM
That was a few years ago. Still going strong and still hold a good "non disappearing" charge.
11-04-2015 6:17 PM
and I cut a sticky lable with the date on it... when first charged.. so i know how long they have lasted....
11-04-2015 8:14 PM
12-04-2015 7:17 PM
Quote from: Force These Vapex claim to be nearly as good as Eneloops, and having used them for a couple of years I agree.
Ive also bought these and they are excellent.
