Recent oddity......worrying?
- Recent oddity......worrying?
06-06-2008 10:16 AM
XP Home SP3 installed
The other day I turned off my computer by using the proper turn off computer procedure.
Three hours later I tuned it back on, but instead of the usual screens I got a DOS screen ( start up IIRC). I used escape and the screen blacked and then started to show close and narrow lines on screen that were moving fast upward. Then finally I managed to close and then reboot, when all started up as it should. Sorry about any vagueness as it was several days back, and since then all has been OK as far as the problem at least.
Should I be concerned, or was it likely a minor glitch?
8 REPLIES 8
Re: Recent oddity......worrying?
06-06-2008 1:36 PM
Probably a minor glitch but you could use a programme such as regcure (costs) or regseeker.exe (free) to analyse your registry for errors...
11-06-2008 12:02 AM
you can also schedule a chkdsk /f for next boot from a command prompt.
11-06-2008 6:12 PM
I ran chkdsk but when the summary appeared, it was on and off screen too quickly to read it. Does ALT/PrtScn work then, or is there a way to keep the summary viewable for longer?
12-06-2008 10:34 PM
No answers to questions then?
13-06-2008 12:04 AM
Doesn't look like it, does it?
13-06-2008 1:24 AM
In the past, when I've not been able to get the computer to do a scrren grab, I've resorted to using a camera to grab a still of a brief screen or one that is repeatedly scrolling to fast. Either a stills camera or a video one where you can pause the video will do.
13-06-2008 9:37 AM
@jnwright lol The dwell time is short enough to be affected by a camera's digital lag.
OT thought: Is a convicted hacker a digital lag?
14-06-2008 2:14 PM
If you just want to view the summary results of the chkdsk, you can find the information in the Event viewer.
To get there: -
To get there: -
- Open the Control Panel
- Double click on Administrative Tools
- Double click on Event Viewer
- Click on Application from the left hand side of the window
- Find items labeled Winlogon under the Source column
- Double click the Winlogon entry to see the summary from the chkdsk
